skunkedskippy
Thread starter- Joined
- Apr 30, 2017
- 132
Hello all, I asked about this in a different forum but will try here as well. I have a 1977 Skipjack that needs a new transom. I’m doing this myself with no experience, and with a lot of help from this site and the people that post here. Old one is removed and new one is cut out and I’m currently trying to dry fit the bravo 2 before I glue it to the hull.
A little background info (to the best of my knowledge): the boat was built with an OMC drive. The last owner had a Mercruiser 5.7 and bravo 2 installed. The installer patched the OMC keyhole with some ply and then cut the merc/bravo hole. This looked like crap so I removed the patch and will reglass it after I glue the plys in.
Now to my (current) issue. I cut the keyhole and drilled the outdrive holes using the skin as a template , before I removed the repair patch. But something was off because the keyhole is not centered relative to the drain cutout. Also the lower right side holes look to be a bit lower than the left. The drive seems to fit ok and if I lay the skin template/patch on top, everything seems to match.
Do you guys think this could cause issues with engine alignment or am I good to go? It’s very possible that the drive was “tilted” from the previous repower but I wouldn’t have noticed because this is my first boat.
Hope this makes sense.
