Hi Folks,
I'm running into a problem this season with the "kid's boat" 25 Johnson mentioned in the thread title. Last season no issues.
Starts fine when cold. Runs perfectly at all speeds.
If I go to start it again while it is still "warm", it is very difficult to start. Seems like it floods easily.
If I wait 10-15 minutes or so after trying to restart when warm, it will usually start up again. (again, seems flooded)
I rebuilt the carb last year and examined it again earlier this season - it had slightly come off of the gasket to the motor so I re-attached it and used a bit of Lock-Tite on the studs - it's holding fine now.
This motor has the manual primer system (plunger). Last time I was messing with trying to start the motor, I pulled the plunger a couple of times (again, when "warm"), and all of a sudden the motor fired right up and ran perfectly. I feel like the plunger may have something to do with it.
I am setting the throttle at the "Start" position each time by the way.
Also, I am running the spark plugs from last year (new last year), and have not yet installed new plugs this year. My fuel is always fresh and conditioned with marine Sta-Bil and Sea Foam.
What else can I tell you to help diagnose?
What should I be looking for with the "doesn't want to start when warm" condition?
Thanks very much,
Dave
Thanks very much,
Dave
