i read the the sticky on top about trouble shooting a no spark situation and according to that i have a bad coil. i have continuity between the small pos and neg but nothing between the larger center plug in and either the pos or neg. that means bad coil? also i was wondering why this coil thats only about 2 years old would be bad so quick. i tested the ohms between the main engine haness plug to the coil and the other end at the coil while unhooked from the coil and get about 2.4 to 2.6 ohms. is this enough to be an external resister wire? the wire to the neg terminal to the main plug read about 1.4. when i test for voltage at the pos terminal of the coil i get about 11.5, is this too much? i
