Hi everyone, I recent bought an aluminum boat that was used in salt water and I likely will use in salt and fresh water. The trailer the boat came with has bunks and I noticed some white-ish water dripping from the bunks and what seems to be the start of corrosion on the hull that rests on the bunk.
My my question is, should I change the bunk for rollers? If I change the bunks, what can I use as a preventitive measure to prevent corrosion?
thanks.
thanks.
