danhenke
Thread starter- Joined
- Oct 11, 2009
- 60
2010 Bayliner 185BR Flight
3.0 Mercruiser, Alpha one
Hey fellas, I was chasing a short today, which I found, but instead of engaging the shift interrupt switch, I pulled it off the cable plate to test it. I see it has slotted holes for a reason. I put it back on and did a continuity in both forward and reverse, shows it closing in both directions. How bad did I screw myself.
it never gave me any issues shifting in an out of gear, and I’m aware it can’t be adjusted without it being in the water with a load on the prop. Is there a preliminary setup that it needs, or should I just mess with it in the water when I get it out next?
Dan
Dan
