Ken007
Thread starter- Joined
- Jul 15, 2018
- 4
[h=1]2008 MERC 350 MAG MPI NO START WHEN WARM[/h]
Will not start when hot very hard when warm, boat idles fine runs fine. Fuel system gone through good pressure at rails. Changed crank sensor, IAC, TPS, ignition coil, distributor and timing adjustments, cleaned MAP, I need help!!! I can idle the boat over tho fuel dock for 3 min and it barely gets to temp, try to restart and it acts like its not getting fire. Have to crack throttle and pump when it hits. If I run the boat hard and shutdown I'm there for 3 to 4 hours before I can get it to start.
