Hello, i just got my first boat about 2 months ago and been trying to fix rpm issue ever since. Its a 2001 maxum with a single 7.4mpi L29 mefi3 engine. It in some sort if guardian mode and won't pass 3k rpm in drive or neutral, in neutral it will go to 3.2k and bounce off like its a redline. I have no engine codes. I did full tune up including ignition module ,coil, fuel filters, map air temp and coolant sensors. Checked base timing which is arnd 8-9deg and it is advancing as far as i can tell. Checked knock sensors,tps, oil pressure switch, fuel pressure is at 36psi idle and 42psi under load, i really don't know what else it could be besides ecm?? Boat beeps twice abt 1 sec each beep when i turn the key on. Manual says beep for 2 sec and says nothing about 2 beeps so im not sure if its normal or not. All fluids are full and i have no alarms. Sometimes when i have a lot of people on the boat it wont pass 2.4k rpm since it can't get on the plane, its like running on 50% power
