Grub54891
- Joined
- Jun 17, 2012
- 6,142
The USGS brought in their boat for repairs, running poorly on both port and stb motors. Determined that there was water/gunk in the fuel, ethanol fuel. Recommended rebuilding carbs, port ran perfect after that. Stb carb When I cleaned it up, had a hole in the bowl, apparently the gunk kept it from leaking. Ordered a new carb from mercury, installed it. The thing won't dial in, I can get the timing at idle set, when given throttle, backfire stumble, quits. Did a basic time a couple times now, still won't run properly.
I think the next step is to swap carbs and see if it helps. just want a second opinion, what else would be the issue,
I did caps and rotors, plug wires are good, and did an ignition module. I was also thinking the coil under the rotor could be going south, but in my experience they either work or they don't.
Engine serial number : 0F 068374
Thank's for any input.
