Rampage 24 Express
Closed cooling system
Mercruiser M048938
Is there any way to test the Sea Water Pump is pulling water? If engine is run for 30 seconds on land, will it drain any water in the sea strainer? (I'm hesitant to run dry... don't want to damage the impeller in the sea water pump.)
When I run it on a hose, the engine stays nice and cool - around 160-165 degrees. Took it out on the water for the first time today, it got above 225 degrees and climbing before I shut it down.
The seacock to the sea strainer was definitely open.
I'm wondering if it stayed cool on hose because hose was forcing water?
Tomorrow, I start diagnosing the overheat problem. Any pointers greatly appreciated.
Thanks!
Mercruiser M048938
Thanks!
