FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
looking for 2 -150 gallon Gas tanks for a 2000 proline 30 sport center console were can i start looking for them and how can I find the dimensions for the old gas tanks on my 30sport proline cc
Well I had them pressured tested the boat mechanic said all was good he checked every thing and I mean everything. But boat still leaks out gas when I fill them up. But it stop leaking after about between 30 minutes after I run the the boat and after that no leak I am just worried someone said might be over filling the tanks. But that what I thought tthe vents lines are for to vent out instead gas goes to bilge pump
Had the same thing happen to me. Turned out to be the fill hoses. Looked fine from above. Once removed, the under side (touching the floor) had rotted to the point the the hose reinforcement wires where starting to rust and poked thru the outer jacket of the hose.
If your fill hoses where like mine,you'll to be a contortionist
Your vent hose may have a kink in it or it's plugged up. Bugs have habit of building nest in the small hoses.try not to fill your tank wide open, squeeze the lever to slow the fuel going into your tank.
You need to find the source of the leak before you spend good money on it. If they hold pressure why would you replace the tanks? Pressure test the entire system from the filler down stream after plugging the vent.
