nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,090
Been having an issue with a floating needle on my tach. Seems more pronounced when hot or at high rpm. I've had the problem before, I thought the issue in the past was some internal corrosion in the tach. It seemed to resolve last time when I worked the selector screw back and forth.
This time, I've cleaned all the grounds, engine, coil, tach. Also tried running dedicated ground to the tach, no change. Ran dedicated sender wire to the coil, no change.
I do have some decreased positive voltage. That's been there to some extent since I've had the boat, but don't know if it's causing an issue now.
I took the DVM to the switch before I took a good look at the wiring diagram, but from what I remember I had battery voltage at "I", which dropped to 10v when I turned the switch on. Purple wire was also at around 10v. This jibes with what my voltage gauge has been telling me for years.
Looks like yel/red at "C" only gets 12v when cranking, right?
Troubleshooting plan:
1. Run 12v from battery to switch, attach to "I". See if I still get voltage drop when key on. (I don't know what the significance of that would be though)
2. See if I get 12v to purple at that point. If so, I have a problem with my main 12v feed.
3. If I still get a drop in purple, but none at "I", I have a bad ignition switch?
4. My gut tells me that my tach is bad, so I guess next step would be get a new cheap tach and see if that the problem persists with that.
Other suggestions?
Other suggestions?
