- Joined
- Jul 18, 2011
- 18,275
Nice, I could have used a vacuum of that sort with all the sanding I have done. . . dust is everywhere
Did I mention that I hate sanding . . . I also put grinding (fiberglass) in that category too.
I found an article pertaining to my latest thought process . . . it is called "Dynamic Pressure Control in VARTM" .
I'm not able to access the complete article, but the intro talks about reducing the vacuum pressure during resin infusion to speed up the flow of resin into the fiber. Then once the resin is injected, resume the high levels of vacuum to saturate the part. Resin infusion times are cut in half and there are improvements to the resulting part. I'm all in, if that be the case.
I'm going to see if I can get access to the full article.
