BarryTurano
Thread starter- Joined
- Oct 26, 2014
- 145
I am at my wits end. I have two 59 gallon saddle tanks. I have been trying to get the tanks to draw evenly. I have added 3 additional feet of fuel line to the port tank. Because the stbd fuel line is 3 feet longer. Figuring that if I can make both runs the same that would help with the fuel wanting to travel the path of least resistance.
I have also tried limiting the opening of the port tank valve. but the adjustment is so small that it virtually shuts the tank off.
I remember on a boat that I had long ago with the same fuel tank set up that I had a switch on my dash (factory installed) that would activate a shut off valve for each tank.
I want to put in the same type of set up on this boat so I don't have to keep opening the motor box and closing and opening valves while underway. I could run x amount of gallons on my flo scan from one tank flip the switch and run the same amount from the other tank. Therefore virtually drawing the tanks down evenly. I realize some of you are saying "who gives a rats ass?" I happen to agree but when you are somewhat anal retentive like me or have ADD you know this will make you nuts.
My question is: where can I get these electric shut off valves?
Thank you for any help.
