LuvBoating
Thread starter- Joined
- Mar 16, 2009
- 718
It looks like a nice plug and all, but I can't see why you would need it.
Somewhere a wire has to be connected to the car's battery. That puts a permanent wire in the car. The other end of that wire has the plug that connects to the winch. Why would you need a disconnect in between? (maybe I'm missing something here).
The easiest way is to buy a small 12V battery, put it in the trunk when you go boating and connect the wire to that battery. No disconnect needed. You can even cut the wire a mile shorter because the trunk is close to the trailer. A tractor battery or a jetski battery should work fine and be real light. When you get home charge it back up. You won't need a mechanic to connect 2 wires to that battery.
We have been told, in this thread, to simply have the wiring done from the vehicle battery to the rear of the vehicle. That way we wouldn't forget to take the battery with us to the lake, if we took it home to recharge. Thing is, we'd have to keep the back hatch open somewhat, so the winch could be connected to the battery, unless we installed a battery on the trailer, just behind the winch.
I honestly don't know which is better, a separate battery for the winch or connecting the winch to the vehicle battery.
