cocaptain5280
Thread starter- Joined
- Aug 14, 2018
- 17
I have a 1957 Evinrude Big Twin 35hp that worked great last season. Unfortunately, due to not having a reliable tow vehicle this year, it has remained in my garage (sad face).
The boat had to be rescued last year in November, and e10 gasoline with stabil was put into the tank to get it back. That gas was the last gas to run through the engine. We did let the engine run, pull the gas line, and let it die. But it is my thinking that some of the e10 gas is still in the motor and fuel lines.
I have since learned a great deal about these older motors, and now I know that ethanol gasoline should not be used in this older motor. Unfortunately, it has been in there for 10 months now...
What should I do? I can run the motor in my driveway with new (non-ethanol) gas this weekend. But what damage (if any) should I look for to see if the e10 fuel corroded any of the parts?
From my knowledge, the motor has been worked on recently over the last several years and had the older rubber fuel lines replaced, since all the inside parts look pretty new and clean. How much should I worry about the e10 sitting in the motor all this time, and is it really a big deal? What would you do?
Thanks
Thanks
