Compression
Reed valves have nothing to do with compression in the cylinder.----That is a fact !-----So what motor do you have and what are the issues with I?
jimmbo
will broken reed valves cause a no compression problem?
Broken reeds will affect crankcase compression, but not cylinder compression unless as Fastbullet stated "Only if they damaged the piston/rings/cylinder wall........."
