newtoboat101
- Joined
- Jul 9, 2015
- 418
1988 thompson 240 /5.0 lx alpha1 gen 1 ,bought from used boat dealer ,redid boat ,took boat out was getting leak back near transom ,so took motor out ,only to find out that y pipe was corroded near bolt holes ,obviously leaking from there ,but since i had motor out ,and have leak near transom ,i took transom (outdrive ,gimbal housing ) off only to discover my gimbal housing was totally corroded on both sides of gimbal housing , in between gimbal bearing and studs to hold gimbal housing on boat ,so i have to get new gimbal housing and y pipe ,took gimbal housing apart and the stamp on it is 42259-c ,,my question is the difference between 42259-c and 42259 , will 42259 work ,are they interchangeable ?besides getting ripped off can any one suggest what to do to make correct
