Arcs&sparks
Thread starter- Joined
- Sep 7, 2018
- 16
Hi all, New guy here from Maine. I am an electrical contractor and fishing fanatic. I’ve acquired a ‘76 14’ Starcraft Holiday that I’m in the process of customizing and rigging up for lake trolling. This would be my second boat project. With this project I am trying to do more research and select better products for my build instead of just grabbing things off the shelf at Lowe’s etc.. At this point I have spent about 20X longer reading forums and browsing products than I have with tools in my hand. I’m hoping you guys can help me out alittle and save me some time as I have a very busy schedule.
What I have done so far is;
-Remove old deck
-Remove saturated foam
-Pressure wash everything
-Wire cup-on-drill inside of hull and thoroughly clean
-Apply Gluvit to entire bottom (inside)
-Prebuild underfloor rod locker (large shallow tub with tubing protuding)
(Here’s where I will accept criticism);
-Fill ribs with Evercoat marine spray foam
-Seal ribs with 5200
-Adhere 1” Styrofoam between ribs
-Trace and cut out new ply
-Seal ply with polyester resin
-Fasten rod locker
-Fasten front half of floor
-Fill installed floor with 2lb floatation foam
-Various other things that don’t matter here
My list of questions starts here;
-What would you recommend I use to seal the wood to the hull so water runs on top and won’t touch my foam (yes I now know you aren’t supposed to do that..) I planned to wire wheel the excess foam and thoroughly sand the ply edge and the joining aluminum, then use either 5200, Dow windshield urethane, or “FlexEpox” (which I already bought but am unsure) to seal between the two surfaces. The foam is thorough, and the wood fits within 1/4 in most places. Looking for opinions..
-My rod locker consists of a shallow polypropylene tub that I wrapped in plywood for structural reasons. I want to seal the gap under the round lip with some goop but not sure what is best For this material. Also the second half of the floor will rest on top of the tub so that will also get a seal.
-I plan to sandblast the bottom of the hull and seal with The Goop Coat-it but I’m left with one thing to scratch my head about. I am unsure how well the rivets are sealed that hold the bottom ribs(terminology?) or if there’s any pinholes etc.. I would like to seal the inside of these ribs as well but not sure the best way. I can hoist/tilt my boat up and down from the I-beams in the garage so I wondered about tapping the pre-existing (2) holes on each rib for a machine screw to thread, fill the ribs with some type of slow epoxy, tilt the boat up and down to wet it out, then remove the screws to let drain... just let me know if I’m crazy and if there’s a better way
FYI This boat will always be trailered,kept under cover while in storage,or in a garage. But may be subject to -30 to 100 degree temps.
-Remove old deck
-Fasten rod locker
