cocaptain5280
Thread starter- Joined
- Aug 14, 2018
- 17
I was waking up an old seahorse this morning and noticed there was a weak dribble coming out of the peehole. I shut the motor off and noticed the back of the motor (where the exhaust/peehole is) was too hot to touch. The inside of the motor was also hot to touch in places.
The motor will will still turn over on one pull, so I don’t think it’s seized, but I’m not running it again until I figure out the heat issue.
I want to check thethermostat and impeller, but the thermostat cover was too hot to touch and the cover is not coming off! Does this mean the thermostat is shot if it got that hot?
Water was coming out of two othe holes that are on both sides of the lower part (just above the water line) - what are these other two holes?
