Wave34
Thread starter- Joined
- Oct 17, 2017
- 367
2 years later, LOL.
I didn't had time to work to solve this problem until this summer.
To resume, the problem is hard start, after sitting for a while, (hours).
The first start is long to very long to no start and requires throttle.
Once it is started once, it fires well afterward, even only 10 seconds later like in my video. So that rules out all the sensors, bad distributor cap, spark plugs etc.
I changed the IAC, because of a bad diagnosis from me, and of course, it didn't change anything.
So, now, theory #1 is either there is carbon deposit behind the intake valve and it absorbs the fuel until saturated, then fuel can go into the cylinder.
Theory #2, there is a fuel pressure loss when the engine if turned off. Maybe some air gets sucked in the fuel rail and at the first start, the injectors are injecting air only.
NOTE: I removed my injectors and tested them one by one with a test rig I have that pressure it with fuel at 50 psi, and over a minute, not one drop could be seen on a towel paper.
I cleaned them anyways with a carb cleaner liquid injected with pressure and pulsing the solenoid.
In the video it takes time to start, but many times, it is up to 4X that time, and sometimes I need to give throttle.
All subsequent starts are fast, even the one after the 9 minutes of resting time and that the fuel pressure dropped down to 10 psi. That negates my theory #2, sort of...
When I left the boat yesterday, the fuel pressure was 50 psi, this morning it is at 0 psi, but the pump jumps it back to 50 in no time.
What do you guys think?
