my bad, sorry, I misread your post. thought it was the flywheel....
-did you use original woodruff key from Merc?
-did you replace the "load ring"?
-did you torque the flywheel nut to specs?
Blue loctite is your friend....
load ring is a one time crush sleeve. It applies pressure to the belt drive pulley and prevents it from slipping.
REPLACE IT
