Porschesolutions
Thread starter- Joined
- Jun 18, 2017
- 49
I’ve lost my second summer now due to this bargain boat buy.
I have a low hour VIP runabout with a 4.3 Mercruiser with a Gen2 Alpha.
Due to mis-tune last year and a dishonest past owner, I ended up with a warped head, mixed fluids, and roasted water shutters, so I just performed a valve job, rebuilt the carburetor, replaced the fuel, oil, gear lube, impeller, plugs, cap, rotor, wires, oil, water shutters, etc- it’s ready to start.
Mixture screw is 1.25 turned out from fully seated.
Idle cam is two full turns in from initial contact.
Timing is roughly 10D BTDC
Disty, wires, rotor are all set for 1-6-5-4-3-2, confirmed compression stroke and via timing light. Mk
Fuel filter is recent and pump is strong when bridged- I pumped out the tank via simply removing the hard line into the carb and powering the pump, it flows well!
Problem is, boat won’t start for more than 5-6 seconds, then dies. I give it a two pumps and start it up over and over to no avail- it’s like the pump works when cranking but shuts off once it catches. I can do this for an hour straight.
I read that there’s a pump cut that engages when OP is low, though OP can be “ok” idling at a mere 4psi so I dunno. I plan to re-bridge the fuel pump tonight and see if it starts in case there’s an active interrupt, otherwise I’m out of ideas.
ok i ran the pump off the battery and it does the same thing.
last night, started the boat with the battery directly powering the pump- no difference.
Verified compression one last time at 160psii across the board.
Anything I might have missed???
