Chris,
I wanted to reach out and suggest a couple of things that will benefit your build. I'm hoping you won't take me wrong.
Lots of guys have made suggestions to move you in the right direction and have been polite.
The woods should all be wet out prior to install, especially the edges and the edges filled/voids, like stringers and bulkheads. The raw wood sucks up moisture like...alot. and goes into rot. Fiberglass is not waterproof.
Everything that goes into a boat.
The wet out seals the wood from water. Additionally when you do glass over the raw wood what happens is not good and becomes a quick project again shortly after launch.
If the wood is not wet out when you go to glass the wood absorbs the resin and pulls the resin out of the glass making a horrible bond if any. The glass will delaminate from the wood after some torque, twists and bends.
Running the glass all the way up is awesome and I did it too. Definitely overkill.
When looking at your glass now their are areas that already appear to demonstrate the bad adhesion.
At the end of the day it's about proper construction and safety for those on your boat.
https://www.seaworthysurvey.com/wet-...may-want-know/
https://www.glen-l.com/methods/how-to-fg.html
