Knotstrait
- Joined
- Sep 24, 2018
- 38
got this motor a week a ago, it was sit for more then 5 years, the guy tried everything to start it, start fluid, change plugs, not even turn, finally he fired it up with drill, two day later I took it to the bay it started on first pull, idle good, I ran it for an hour trolling speed, after that took it home flushed it, and next day I saw the dark oil/gas leak out from lower unit connect point, (showed as picture). Both cylinders has 70 psi compression, what can I do to stop the leak? Thanks for any input!
