JonNmtJuliet
Thread starter- Joined
- Oct 13, 2018
- 57
Did I miss where you re-filled your stringers with foam?
Fun project to follow along, making good progress.
I dont know anything about that tank unit, but I'm sure someone on here will!
No you didn't miss it. I'm going to drill and fill them after I get the floor down. So holes through the floor into the stringers and holes through the floor to fill the empty cavity's. I'll do this before I lay the glass down. That way I can put the plugs back , fill in with thickened epoxy then glass. My only thread of logic for this path is that I wanted to foam all at the same time and it should be easier to fix the holes with the wood plug. I did glass over where I cut into the stringers before the floor went down but i don't think I captured that. Also, I either need to block the opening where the motor mounts go or rebuild them before I foam. I think I want to put them back where I can use pass through bolts instead of lag bolts.
I'll keep chipping away at it...
