roffey
Thread starter- Joined
- Nov 22, 2012
- 2,206
Last year I took my alpha one out drive off to check the water impeller and fix a broken sag. I put the drive back on but noticed gear lube leaking from the prop. I must have missed a seal or crushed one so I took the drive off to inspect it and think I found my problem. I believe there is a seal missing where the drive connects to the upper case. Question is there a seal that goes between the two halves, if not them my search continues…
