sms986
Thread starter- Joined
- Sep 18, 2017
- 334
The boat I am working on is a 1989 mercruiser alpha one with a 5.7 and thunderbolt iv ignition. I am at WITS END with this thing. I have had issue after issue and every time I fix one another pops up. Today's issue:no spark. I did a compression test before I left and stupid me forgot to ground the plugs when doing the test. Well, I got back today, a few weeks later, and tried to start the boat. No spark. I replaced the coil with the one on my car (same coil, works for sure), replaced the cap and rotor, and tested the old coil. Old coil was fine but I left the other one on for now. I have no power to the coil. Should have 12 volts. Tried doing diagnostics based on the forums, because I am not an electrical guy whatsoever. The only evident issue I have is that there is a radio that is spliced into to one of the power wires from the coming from the fuse box (one of the access fuses) and grounding to the back of the tach. The wire going to the radio has a fuse on it. This fuse blows every time I turn the main battery switch on. None of the fuses under the dash were blown and this radio has always worked fine. Other than that, I don't know where to start looking. The wiring behind the dash is just a swamp. Does anyone have any methods for further testing?
