Tach for a 1969 25hp Johnson non- electric start...
dfrants
what kind of tach do I need that will work on a 1969 25hp Johnson tiller?, model no. 25R69D. looking to test some props and want to see the rpms she hits.
Joe Reeves
Just in case you're not familiar with the term..... Jasper isn't describing any ole tiny tach..... "Tiny Tach" is the name of it.
oldboat1
I bought one of these: Neiko 20713A Digital Tachometer. Non contact Laser Photo.. Seems to work well on just about anything that spins! (Used it to check the boat tach readings.)
dfrants
I looked at a couple of tiny tachs on line and they say that they have an internal battery that only lasts two years and can't be replaced??? Is this correct?
kbait
I bought a Chinese cheapo tiny-type tach 3 yrs ago with internal battery for $10 or so. Still working fine.
dfrants
I see there are several different Tiny Tach models. Some models are "R" and some are "NR". is there a preferred one for outboards?
F_R
If I were buying one (I'm not), I would be seriously considering the non-contact laser-type. Matter of fact, on second thought, I may look into one for using on my machine tools.
