JettechTN
- Joined
- Nov 26, 2018
- 5
New member... Actually old member but they decided to scrap the old login since it was years in between logins.
I have a 07 Merc as stated above with an issue that I cant seem to get so looking for help. All the info you need is below.
Mod-115ELPT4S
Ser- 1B510416
Boat sat for about 4 years with no use. It only has 20-30 hours on it. Started with flushing the remote fuel tank, replaced primer bulb and line. Started off with clean fuel and a seafoam mix that we use with the watercraft. Motor ran for awhile on the hose until it hydro-locked with fuel due to the vac line in the VST that was cracked. Removed fuel from cylinders and removed VST and replaced the following items:
High pres pump
Low pres lift pump
Float assy.
O-rings and seals
Vac line
Both fuel filters
Injectors cleaned
Plugs
Oil & filter change
Runs great on the hose. One the lake test it runs at low speed great. At WOT it dies after 5 seconds because the VST runs out of fuel. Fill the VST again with primer bulb and run it again but it will die after it runs out of fuel unless your at wake speed to mid throttle. The filter going into the VST never stays full unless your using primer bulb. Note that the 2 pumps and float are aftermarket not OEM. One new item to add is that now after the float was replaced I will get a 5 second long buzzer and it will sound every 10 min. Any ideas before I lose my sh*t over this motor would be greatly appreciated. Thx
Mod-115ELPT4S
Ser- 1B510416
High pres pump
Low pres lift pump
Float assy.
O-rings and seals
Vac line
Both fuel filters
Injectors cleaned
Plugs
Oil & filter change
