- Joined
- Mar 8, 2009
- 43,771
The block holds most of the coolant. Disconnect the large hose on the engine water pump, then fill with straight 100% AF. Run it some up to temp and then check the mix at the HE. If its the correct mix your good. If its lower then need to be, your going to have to drain some more and refill again.
If you had raw water, all of it needs to be drained or the block cracks if it get cold enough
