How to manually reset the Guardian Alarm
What code are you getting?
The alarm normally resets on its own once the fault has been fixed
Just noticed this is an OB, so not my expertise, but do have a manual for
Assuming you have the system monitor display and it is showing guardian mode?
A continuous beep with guardian list, engine over heat, over speed and possibility low oil pressure.
The key is ON and alarm is sounding, what happens when the motor is started?
