Davidsgara
Thread starter- Joined
- Jan 25, 2019
- 60
So the quick valve flush system is a waste of time?
My set up is 350 mag mpi/alpha GENII raw water cooling and I flush the engine every end of weekend while the boat is docked. I made two adapters with quick connect fittings. The one adapter fits at the hose coming from the drive and the other at the steering cooler in which I supply the engine fresh water from the marina tap. I connect a water hose (2m length) to the adapter fitted to the hose coming from drive so to bypass the salt water coming from impeller and I start the engine. I adjust the flow of the fresh water so the engine temp to be steady above 72oC let's say 80oC so to secure that the Tstat is open and so the fresh water inserts to the block. It is really simple and good system. I use it for 2 years now. I thing this is the most simple and cheap way to flush the engine with fresh water with boat docked.
One other advantage of this method is to check and measure real time the water suplied from the impeller at every rpm range! Really useful!!
