Data sheet is here
https://samerwebapp01apncus01.azure...43l_alpha_4v_product_data_sheet_8m0080486.pdf
225 hp with 4 bbl carb
Ok. Had a look there. It’s a remanufacture engine. Not a newer previous engine brand new. Basically an overhauled engine.
Data sheet is here
Way back when Merc was still using the pre-vortec V6 they sold them with Quadrajets, and probably did sell them with the Weber copy of the old Carter 4bbl.
They sure did. I had a couple. But they weren’t 225 hp in their most powerful 4 barrel form, they were 205hp standard. More usually 190hp and about 175 in 2 barrel form.
225hp is with Vortec heads, and a 4 bbl carb (probably a Weber). Yes, they aren't 'new' engines, they come from Merc's re-manufacturing section, but they are still 4.3L, 225hp....
Don't quote me on this, but I suspect that 225hp is at the crank. The 4.3MPI is 220hp at the PROP.... So 225 at the crank and a 4bbl and vortec heads is on par with a 205hp at the crank with non-vortec heads....
Chris.........
You’ll be right, I’m sure Chris.
My point, at the risk of trying to save face haha, is that the chap who posted the question originally, has a 2004 engine. That wouldn’t have been 225hp with a 4 barrel carb in those days surely ?
There is still no 225hp carb put in a new boat now, even. You would need to buy a remanufactured one.
