tennvols93
Thread starter- Joined
- May 23, 2018
- 25
Good morning folks,
I know this will be a strange question, and without running the boat, it will probably be difficult to help/answer. Yesterday, I pulled the cover off the boat to change out my damp rid buckets in the boat. I popped the engine hatch to look around and noticed a puddle of antifreeze under the motor. When I winterized the boat, I cleaned up all the antifreeze that I may have spilled (there could be a little I missed). I winterized this boat according the manual which was to drain the water through the single point drain, remove the thermostat and pour RV antifreeze into the thermostat until full.
During the summer last year, there was only one occurrence where my bilge had an excess amount of water in it and I took the boat out probably 30-35 times. I do suspect a leak somewhere and wanted to inspect and look for it during dewinterization. I suspect a leak because of the amount of water drained when the plug is pulled. This could be normal though for this type of boat? I'm not 100% sure to be honest. But the boat drains for about 1.5 - 2 minutes. The only reason I did not do this during winterization is due to me having to go out of town unexpectedly in October for an extended period of time, so I wanted to get it winterized before leaving. I know this info is vague, but hopefully someone may have experienced this. My first thought was the dreaded cracked block, but the boat runs excellent, and my oil looks fine as well?
