Bannister 6905
Thread starter- Joined
- Jun 5, 2015
- 110
The saga of the Force 90 continues...now that I've all the gremlins previously noted fixed, another one has popped up.
The motor starts immediately and idles well. After about 30 seconds, it leans out and stalls. I pump the bulb until hard (i can hear it filling the carb bowls) and it immediately restarts. I take off and it accelerates and cruises smartly with no issues. Then, I stop, shut the motor off for a bit and try to restart after a pause. The bulb is not "soft", but is certainly not "hard" and the motor will not start. I pump the bulb several times, hearing the carb bowls filling and the motor starts and runs well again. There's no hint of the bulb collapsing at any time.
I have replaced all the fuel lines, rebuilt the fuel pump, replaced both fuel pump manifold gaskets, cleaned the filter and made sure the carbs are clean and adjusted properly. The only thing I haven't replaced is the bulb, although I did clean it out thoroughly.
I have confirmed that I rebuilt the fuel pump properly, all connections are tight and there are NO leaks and no flooding.
Has anyone else had a similar issue and what was the fix?
Thanks.
Bannister
Thanks.
Bannister
