midnightrider1818
Thread starter- Joined
- Aug 17, 2009
- 190
Ok getting ready to do bellows trim senders and lower shift cable. What do you guys use to run up the shift cable before you pull it for a guide. I was thinking weed eater string I guess. Also my gauge nor my trim limit works. I bought new senders. If I take my trim limit wires and hook together then my trim limit switch should work right. It's just a switch. Also my trim gauge sender just goes to ground right. So if I ground that wire my gauge should move. First time messing with senders so tips and advice needed
