gm280
- Joined
- Jun 26, 2011
- 14,605
That's why I'm needing this drain standpipe.
I was trying earlier to post a question, but the system wasn't allowing it.
So you tried a typical black iron 3/4" threaded pipe and it doesn't fit, and you tried a 3/4" PVC threaded fitting, and that too doesn't work. Did either start threading into the drain fixture at all? And is the drain fixture metal. Can you remove the drain fixture?
