PensacolaJason
Thread starter- Joined
- Oct 23, 2011
- 176
I had my boat out the other day and it ran great for a while, but when I would drop it back to idle it would die on me and then I'd have to work with it for a bit to get it going again and then it would run fine at middle to high speed. The only issue I would have was when I would lower it to idle.
When I was trying to idle it one time I noticed a small gas slick in the water surrounding the motor (1996 Evinrude 130hp - E130TLEDM). I popped the motor cover and air box off and found that the overflow hole on the front of the carb was pouring fuel. What I know, or at least think I know, is that this means that my needle isn't seating like it should causing the fuel to continue filling up the carb bowl until it has nowhere else to go.
I got home and took the carb apart. I inspected the float, needle and seat and everything looks fine to me. I even turned the carb upside down and blew into the fuel inlet bar and could not get any air through, so I know it's seating at least when held upside down. My main question is that I've seen contradicting information about how to adjust the float height on these plastic carbs with the float in the bowl. On videos, I have seen people use the hinge pin screw to adjust the float height so that it is even with the lip of the float bowl. So they'll tighten the screw all the way, flip the carb bowl upside down and then slowly loosen the screw until the float is even with the lip of the carb bowl.
In my manual I get contradicting directions, it says to "secure the float assembly with the phillips head screw and tighten it securely" and make float level adjustments by bending the tab.
When I tighten that screw all the way down, my float sits down so far into the bowl that even an extreme adjustment to the tab over the needle valve doesn't seem to make the float level with the lip of the float bowl when in the closed position.
Am I doing something wrong? Should I only be adjusting float level using the tab over the needle or should I be using the hinge pin screw for the adjustment as well?
