DONT SAY POLTERGEIST: Tohatsu 9.9 faint high pitched noise only when in gear
vdotmatrix
My outboard will make a faint high pitched squeal only when put into gear. It is so faint you won't hear it once the RPMs come up.
Any ideas?
Sea Rider
When gearing forward is the gearing operation smooth or with an audible clack to the ear ?
Happy Boating
pvanv
What is your actual model/serial? There are differences, depending on whether it's a 2-stroke, carbed 4-stroke, or EFI 4-stroke.
The 9.8A3 was known for a whistle in the intake air silencer around 2000 RPM.
Has this happened right along, or is this something new? What have you done to address the whistle, and what were the effects?
vdotmatrix
(mss9.9b2) 9.9 hp
I don't have the serial number, but I have people complaining about this noise that seems to be getting louder or at least more noticible.
vdotmatrix
I will get back and answer questions..THANK YOU SO MUCH for responding.
pvanv
The MFS9.9B2 (4-stroke) could whistle through the intake, but I've not seen that.
vdotmatrix
I went to a tohatsu motor forum , wait I am here! I haven’t done anything , just waiting for something to happen.
Sea Rider
The 2 strokes 9.8 was known to whistle through the carb, but this is a 9.9 different horse. Does it continues with the high pitched squeal. Only happens at low rpm and quits at higher ones ?
To be sure remove the cowl, put your ear close to carb and throttle, check if the noise is coming from the carb silencer or not ?
Happy Boating
pvanv
Happy Boating
The MFS9.8A3 and the MFS9.9B2 are completely different blocks.
