Boatrunner1
Thread starter- Joined
- Aug 7, 2018
- 14
I noticed when examining the gear oil resevoir hose (outdrive removed) that when the bell housing is lifted to its highest point the shift cable bellows expands and then slides on cable casing. When the housing is lowered the bellows contracts and slides back on the cable casing. The narrow end of the shift bellows is secured by a nylon wire tie.
I didn't have any water in the bilge last season. I am wondering if it is supposed to slide on the cable casing or should i secure it tighter with a ss clamp so that it doesn't slide on the cable when the bellow is expanded.
If the bellows shouldn't slide on the cable casing, I will tighten it with the clamp by gradually tightening the clamp until I reached the point where it doesn't doesn't slide on the cable casing when the bell housing is lifted to its highest highest level, as not to retrict movement of the inner shift cable.
Any thoughts?
Thanks
Any thoughts?
Thanks
