altitude 411
Thread starter- Joined
- May 24, 2018
- 78
Replacing water pump on A1G2 and I'm having trouble removing the plastic seal carrier below the water pump. Doesn't it just lift off/pry off with a couple of screw drivers off the drive shaft. I've put quite a bit of force to it but can't get it to budge. What am I missing? should I pu
t some heat to it with a heat gun to warm it up? Is it suppose to get some sort of sealant on it to seat on the shaft upon assembly that is holding it now?
