1964 3hp driveshaft won’t go back in pinion gear
Turn case upside down and it slips in.-----Always worked for me even without taking it apart !!
This should be easy.-----But I am not there to look over your shoulder.----Something is wrong if it is not " easy "
BlackoutBill21
Not for nothing but I ask a lot of questions on here and you always reply. However you always have some snarky comment. If you could refrain from answering my questions from now on I’d appreciate it. you’re more of a bother than help thanks
kbait
Look down the hole with a flashlight..you’ll see that the pinion gear hole is not lined up. Then take a thin screwdriver and try to center pinion and try again..and again.. it will eventually slide in, but can be frustrating 😎
F_R
Hold the gearcase with drive shaft horizontal and prop shaft pointing up. Jiggle the shafts a bit and it will slide right in. Easy.
BlackoutBill21
Yup tried all of that... guess I’m just getting unlucky getting it lined up. Just wanted to make sure there wasn’t a clip or something holding me back. thanks kbait yeah my arm hurts and I’ve held it every which way. Frustrating is an understatement.
F_R
Don't know what else to say, except I've had it work for me many times. No snark intended.
BlackoutBill21
None taken from you FR. You never have. Alwaysbthe professional. No clearly I’m doing something wrong. I’ll keep shaking and wiggling
F_R
My wild guess is you are pushing on the drive shaft too much as you try to "find" the pinion. Easy does it. The pinion has to fall into place to where the shaft will slip in without pushing the pinion out of place.
lindy46
If you shine a light down the case and you move the case around, you should see the hole in the pinion shift positions. If it doesn't, something is binding. If it does, when the hole is centered, hold the case in that position and slide the driveshaft in.
BlackoutBill21
Success! Yeah just took some finagling.
what worked was to stick the prop shaft and gear in without the carrier and use that to wiggle the pinion gear. Slide right in...
very easy
Tim Frank
very easy
Hmmmm...just like Racerone suggested.... :)
Cannot imagine why you were offended by anything anyone responded with, but that is just me.
When I post in here looking for help I am just grateful to the folks who take time out of their day to try and assist me.
BlackoutBill21
Helping is simply saying what to do. He leaves a smart *** response EVERY time I post a question. There’s a difference. I don’t want help if I’m being made feel stupid. FR usually responds as well And he is always respectful and helpful. As well as everyone else who responds. It’s just this one dude who can’t keep out the extra rhetoric.
