dlogvine
Thread starter- Joined
- May 4, 2015
- 839
My original lower unit for 4.3 v6 came with a chipped edge on the lower unit. Since there were 4 holes I assume that this chipped piece, about 3 inches by 1.5 inch came from installed stabilizer fin. Anyways I purchased a lower unit for alpha one gen 2 and now I'm trying to figure out a couple things. First, is the lower unit universal for all gear ratios, or is it specific to the type of an engine? There is no marking on it, the gear ratio is marked on the upper unit. And the second question, the housing is in perfect condition, but I'm not sure if the gears and the bearings are good. The prop shaft and gear shaft spin noiselessly and easily, and both look straight, at least at the sight, but is there a better test for this? Thank you
