ab59
Ensign
- Joined
- May 10, 2017
- 991
Lou I'm not sure of anything anymore , but , that same adjustment is what I am looking towards as well. I am going to take all the cables loose one more time( including the throttle cable ) and re-set everything. I will try to get a close up of the control box cable ( upper cable at racket ) to show you that I have about 1/2 " of threads showing there at what is supposed to be some kind of Trunion . I adjusted it out so far when I was trying to find the correct " sweet spot " and now I am thinking that I need to take everything loose again and return the control cable adjustment to whatever makes the switch button line up with the actuating cam and then try to get the shift arm adjusted to achieve the correct placement . I need the shift actuator to kick hard enough to trigger the interrupter switch and so engage the ESA. At least that's what I'm going for.
I'm going to get this right . Somehow it feels personal now :lol: .
More video tomorrow to help explain my thoughts.
Thanks Lou---- A.B.
Thanks Lou---- A.B.
