andrewterri
Thread starter- Joined
- Jun 25, 2014
- 437
I am adjusting the alignment on the 2014 4.3 MPI. The bar is showing grease spines on the top and nothing on the bottom and bar is not going in smoothly like it should. Don S has a great right up but doesn't say if i need to loosen the rear motor mounts to adjust the front, or I just missed it in there. I have not done that before but doesn't mean I was doing it right. Can i just adjust the front and leave the rear mounts tight? On the 4.3 mounts do I just loosen one nut than adjust with the other? i.e.. to take the engine down I loosen the bottom nut and adjust using the top nut from each side?
