Volvo Penta SX M1 out drive
Chuckles88
I am looking to replace the 6 nuts that hold the out drive on. The dealer I use is an hour away and told me that a stainless lock nut from Home Depot will work. I took an old one off and it appears to be aluminum? Does it matter? I have read 25 and then 50 # of torque but I can’t seem to find the tightening sequence. Thanks!
Fun Times
Yes OEM nuts are recommended to help prevent other issues such as nut galling and corrosion....Volvo part number 3853329 ..., http://ww2.iboats.com/Boat-Parts-Acc...=3853329&s=sol
Some past discussions for you too if interested regarding these nuts,
https://forums.iboats.com/forum/engi...-outdrive-nuts
https://forums.iboats.com/forum/engi...ttachment-nuts
Tighten the nuts in two steps. Use 3/8 in. drive, 5/8 in. swivel socket to tighten nuts to an initial setting of 25 ft. lb.. Start with center nut and work in a crisscross pattern to secure the stern drive to the pivot housing. Use the same crisscross pattern to tighten all six locknuts to a final setting of 50 ft.lb.
http://boatinfo.no/lib/volvo/manuals...rive.html#/234
Ayuh,..... If Volvo is like Merc, the stock nuts are chrome plated brass,......
As FT says, Stainless is Not the way to go, as they gall, badly,....
Lou C
On the Cobra which is very similar, I have never replaced those nuts, all I did was coat the threads on the 6 studs every time I installed it with OMC gasket sealer, or Permatex Aviation, and never had a problem with one backing off or not coming off when I pulled the drive. I know they say to change them, but I have not found that to be necessary, just coating the threads and getting them good and tight.
dypcdiver
20 years removing drive every year as boat is used 7 months a year in salt water and I am still using the same nuts. Brass chrome plated. Your choice.
Fun Times
Original nuts from new or newer bought nuts from Volvo?
dypcdiver
Original nuts from new. I know Volvo says replace each time BUT it is my choice on my boat. If it was someone else's boat I was working on then they would be renewed. Which is why I said "your choice".
