- Joined
- Mar 8, 2009
- 43,537
Is it possible the chain could slip or break maybe ?
Anything is possible, could also have bent rods or other things
MPI Engine... Doesn't use distributor position for spark timing. Uses the crank angle sensor.
QBhoy Have you put a Diacom-loaded laptop on it yet?
Chris..........
If it had broken the timing chain, with the ignition and fuel OFF, you'd hear a difference in the way it was cranking. You'd hear some cylinders not compressing.
Also, with the chain broken/gone, the ECU would get on cylinder position information, so you'd get no fuel injector pulses or sparks.
A really quick and totally positive check for the chain is to lift the dissy cap and crank the engine. Dissy turns, chain good, dissy no turn, chain not so good.
Chris.....
...What you think ?
You're the man on the ground. We can only advise based on what you tell us you're seeing/hearing.
Me? I'd be putting my Diacom-loaded computer on it and see what the ECU is seeing and if there are any codes set... I'd use that to rule out any ECU/sensor problems, then start on with the mechanical side. But until you can rule out the ECU/sensors, it's a complete guessing game.
Chris.......
Hi all. Needing some advice. This one has me stumped.
A friends engine recently locked up when out. Was at high speed, slowed down and stopped it. Went to start it and it locked up.
So having spent some time at it myself, we have ruled out the manifolds and risers. They have been pressure tested as good.
All 4 plugs on the port bank have water.
Now here is the weird bit....with manifolds and risers off...it will still lock up with a terrible noise, when trying to crank. BUT....if I trip the lanyard cut out switch to kill ignition and fuel pump...it cranks over just fine and doesn’t lock. This would make me think the water is coming from the fuel injectors ??...but I’m pretty sure it doesn’t have cool fuel or an interface for the fuel and water to mix....and the other starboard bank is clear of water...so surely not from the fuel ??
just to recap...it cranks over fine with no ignition or fuel...but with ignition and fuel it locks up. What’s going on ? It’s run since winter, so not likely to do with frost damage we think.
Thanks all.
Were you on the boat when it happened? Did the motor suddenly shut off out on the water at high speed or accidentally get shut off at high speed when it threw the serp belt? If so that would explain water coming into the cylinders.
... Going to be interesting to see what a scan for codes will show for a mechanical issue
HHmmmm… I think it's a timing issue myself. After messing with it a few times, it's pretty easy to mix up the plug wires. Or the chain jumped a tooth or so.
Chain jumping a tooth wouldn't change the timing. This is an MPI engine, timing is controlled by the ECU and the crank angle sensors, not the distributor...
Hi again.
I wasnt on it at the very moment. I was on my own boat and later towed him and family in. Just to get off the water safely.
Since posting this I’ve talked to him more. Exactly this happened.
He was running wot flat out for a few mins...slowed down to idle. Didn’t stop engine (as first thought). Idled for a few minutes. Went to take off and opened throttle and it stopped at little more than idle rpm. It then would start again. Noticed belt was off. Put back on. Same.
A few few days later I pulled all plugs and lots of water from port bank. All cylinders. Oiled bores and replaced plugs. Cranked for less than a second. Same again. Figures all plugs and cylinders being wet, must be from a common source like manifolds and risers. The usual. Despite it being a slightly heavier noise than anything I’m used to when the starter locks. Didn’t sound like the starter locking. Took exhaust and risers off to pressure test. All good.
Currently port exhaust and risers off. Plugs in and dry. Turns over freely as you like with no noise with lanyard kill activated so no fuel pump or ignition. Turn it on and crank. Big Bang and halt. Doesn’t even get to fire up. Slight kick and bang instantly. Pulled plugs. Not much sign of water. Perhaps only slight residual.
What are you thinking about the belt ?
What model boat is this? Big tub? Has the original motor been replaced? Is the riser height vs water line correct? Does this exhaust system have spacers? Sounds like he came down off plane and sucked water back in through the exhaust . Perfect storm would happen if the riser height was too low, burned out shutters, extra weight in the back of the boat.
after you turned the motor over to get the water out and oiled the cyls, the second time you turned it over and more water came out was most likely just left over water from the initial gulp. Can be hard to get it all out of there. I usually get out as much as possible, fog the cyls then Run it right away on the hose. Hard to start but it'll eventually start and smoke like mad for a bit.
It’s a maxum 2400 scr cuddy.
Probably 3" spacers at a min.
