kcassells
- Joined
- Oct 16, 2012
- 8,738
Get prepped for the bilge drain. You will need a few things. Don't throw something in directly thru/on the hull. You'll need some glassed wood @ 1/2" to 3/4" to secure the unit glassed to the hull/transom to accept the device or other design alternatives.
I've seen some set ups that have the pumps on a aluminum type tree that you can just hook to the sides vs. the bottom hull.
Check out Dave Pascoe bilge pump info.
Looking forward to your install.
https://www.davidpascoe.com/marine_i...ons_chapt5.htm
Something like this but there are other designs;
