MPrimeaux
Thread starter- Joined
- May 10, 2019
- 240
I have been following your progress from the start and I'm impressed with the outcome; love it.
I had a 1962 Arkansas traveler with pulley/cable steering so I have one tiny advice to add, that could be significant.
Check the screws/wood that the pulleys are secured into the boat with; they can come loose (not good at high speed as you loose control of any steering, luckily mine happen when docking)
Thanks for the heads up on the screws and also for the compliment brother. I have checked the fasteners and for them to come loose would actually require bolts to pull through the glass sideways. These pulleys are attached to bolts that run vertically through where the top cap and the hull are seamed. Kinda hard to describe, but you can see in the pics. The bolts are actually put through the flange of the boat from the outside and have a lock nut on bottom. They also use a HUGE "S" hook. I think I'm ok on them pulling out, my concern is the new pulleys I purchased have a "hook" and not a "loop" (you can see what I'm talking about on the new pulleys on the motor bracket). That is one of the reasons that I didn't replace the pulleys that are under the top cap that I can't see easily. I've read where a several people have used these without issue as long as the cable tension is monitored and maintained. The original set up didn't include springs. I added them to for a little insurance to make sure I keep tension on the cable. Thanks a bunch for the input my friend and please don't hesitate to holler at me if you see any other concerns or issues that you think of!
