kbh121956
Thread starter- Joined
- Jun 30, 2013
- 504
Hello group. I have a 1972 18' StarCraft SS. The floor had a soft spot in it. The PO had screwed a umbrella mount to the floor and didn't use any sealant on the screws, overtime the plywood absorbed water and caused the ply's to separate. My question is, what type of plywood is needed for it? I will only be replacing 2 sections, the 2 back sections. He mounted the umbrella right on the seam. What it has in it now is 1/2 inch. What grade should be used and is it a Lowes or Home Depot? Also, I have long white strips of foam in the boat under the floor, A different group told me that it shouldn't have foam under the floor. This is a factory floor, I am the second owner of the boat. The boat seldom went out. The foam is dry and still white in color. The aluminum is still bright and shiny under the strips of foam and the rivets show no sign of leakage. Thank you for the help, this is my first aluminum boat and I'm loving it. So much lighter over my fiberglass boats. Sorry I have not been able to post photo's.
